This error message:
![Image]()
Is not a Genesys message, it belongs to Modelithics. So do these windows:
![Image]()
![Image]()
If you have a valid Modelithics license, point to it with the path selector, if not, uninstall the Modelithics library, otherwise, you'll never see Genesys run again, you'll always get this odd licensing window, and will be stuck in a loop ad infinitum (a customer description, not mine).
Only way to remove it is from the "Add/Remove programs" where it is conveniently listed with this name:
![Image]()
Peachy ain't it.
Peachy ain't it.
