Problem with units in user models
Question asked by twilke on May 20, 2005
Latest reply on May 23, 2005 by rrobbi
Units is user models appear to be forced to the defaults. This causes numerous problems when you create a user model by copying from existing schematics.
For example, I had a schematic that had a few capacitors with units set to fF. When I copied them to a new user model schematic, the units displayed on the schematic still showed them as fF, but the simulation results were different. I discovered If I looked at the part properties the units were actually set to pF and the unit could not be changed.
It appears that you can only use default units in user models. WHY???
Using Genesys 2004.7
Tony
