Hello!!
How can I measure a degradation by Mismatch filter matched if I use a Raised Cosine filter at the transmitter?
In this case, Should I use a I&D filter at the receiver?
If you have a RC filter in the transmitter, then you need the same filter in the receiver.
WARNING!! This combo produces ISI which degrades performance.
That is why most systems use a root raised cosined filter at both ends.
Good luck :o
