The new version of Flex LM which is installed with GENESYS 2004.03 tends to cache old license versions. You can tell that it is doing it if when you start GENESYS 2004.03 for the first time and it doesn't go through the authorization wizard. The caching problem can be fixed by running a simple script the script is available for download at the bottom of this message.
Simply save it to your computer, unzip it, and double-click on it to run it.
Scott Platt
[file]cleanflex.zip[/file]
Scott Platt
