Hi all, I am using a 4402b spectrum analyzer, when I set the CDMA frequency reference to be External, there will be a picture show up, indicate how the cable should be connect in the rear panel, you have to push the ESC button to make the picture disappear.
The problem is I can't find any information about the ESC button from the programming guide.
Could someone tell me how??
Thanks a lot!
Thanks a lot!
There isn’t a remote SCPI command to press the escape key. This issue may have been fixed in a later revision of the CDMA personality to only show the picture when setting the reference via the front panel and not when setting the reference via remote SCPI command. Please try installing the latest version of the CDMA personality.
Hope this helps -
