Using VEE to collect trace_data from an 8565E and write the values to an Saccess table. I figured out how to get the trace data to a 1d array and itterate through, but having a bit of trouble getting the frequency points. Do the frequency points have to be manually built into an array with the a linear ramp? Dont the number of points vary depending on the span and the RBW? Just need a little help here. Thanks. Next job is to get the frequency points and each trace data points put together for building the SQL insert.
