I am using LabWindows/CVI to automate my VSA 89600 (running on MXA).
In order to do so I am creating an activex controller which allows me to access the VSA api functions. Most of the time everything is working fine but some times I have all kinds of problems: VSA application loads as simulated hardware, VSA application get stuck and does not respond and more.
It is a very problematic situation since our work rely on those automatic tests.
I have attached a screen shot of the latest error I got - once it happend the VSA stopped responding to mouse and keyboard. Pleae - If anyone has encountered such problems and know how to deal with them I will be thankfull to get some advices.
[/img]
[/img]
If you do not receive any suggestions from our Forum community, I suggest you contact your local Agilent Contact Center.
http://www.home.agilent.com/agilent/con ... =eng&cc=US
To start troubleshooting they would need:
VSA version number.
Setup file showing the VSA state prior to the error occurring.
A list of commands sent to the VSA to cause this error.
A description of the measurement hardware including model, options, version, etc.
Regards -
