Hello
I'm trying to control the VSA Software using Matlab in order to measure the magnitude of a Spectrum, and the phase when the x variable is time.
My question is, how can I set the Trace in order to have, for instance, Main Time.
Using the help, what I understood is:
Trace-> Data Name Property-> Mean Time
I wrote in Matlab the following script :
oTraces=get(oDisp,'Traces');
oTrace1=get(oTraces,'Item',1);
oTrace2=get(oTraces,'Item',2);
enumVsaTrc1Format=0;
enumVsaTrc2Format=4;
set(oTrace1,'Format',enumVsaTrc1Format);
set(oTrace1,'DataName','Spectrum');
set(oTrace2,'Format',enumVsaTrc2Format);
set(oTrace2,'DataName','MainTime');
Matlab returns an error that says
Source:Data Name
Description: Unknown Trace Data
I'd be grateful if you could tell me how can I show two traces, one showing the Spectrum, the other Main Time.
Thanks
Edited by: tabbott on Mar 21, 2012 3:46 PM
Source:Data Name
Thanks
Sub Main
Display.Traces(1).DataName = "Spectrum1"
Display.Traces(2).DataName = "Main Time1"
End Sub
