Hi
I have been searching the SCPI command to transfer states and images from my instrument to the computer, as I do with my other Agilent instruments, but I've seen no command to do. Any suggestion??
Thank you
Thank you
The NFA uses the same SCPI method for uploading and downloading files that the PSA/MXA/PXA/EXA/CXA use. There are examples of using the MMEM:DATA command for Signal analyzers posted here: www.agilent.com/find/sa_programming
One of the examples sends a SCPI command to the SA to store a screen capture and then uses the MMEM:DATA? command to transfer the file to your PC. There is also an example to upload a file to an SA using MATLAB.
Regards -
