Yes. For example the first ATC2 core with 16 output pins could be mapped to the outside of a mictor connector with its corresponding clock. A second ATC2 core with five output pins could be mapped to the even side of the same mictor connector. A separate logic analysis module is required to collect acquisition data for each core.
