Can anyone tell me how to use external instruments in thru-put multiply test ?
We have 2 module systems.
I have added in board config file:
module 2
ports ext1, ext2
connect "ext_device1" signal to ext1
end module
module 3
ports ext5, ext6
connect "ext_device1" signal to ext5
end module
now in the analog lib, I setup:
connect "ext_device1" to pin 1
pause
report analog ....
My panel is 10 units, when I ran IPG, I got the error: "The instrument "ext_device1" is in a module different than the board module. (ERROR ATL282)"
How to fix this ?
Thanks
module 2
ports ext1, ext2
end module
module 3
ports ext5, ext6
end module
pause
report analog ....
How to fix this ?
Thanks
