i want control the user right on 3070 ,one group can only use the program ,can not modify all program .one group can modify all the program .when i setting the right in folder property security tab (read&execute ,list folder,read ) .the BT-Basic can not run ,it can get testplan ,but it can not run ,when i setting the full right on this folder,it can not control the right .in unix ,it can control right by "chmod ,chgrp "command easyly .anyone have good idea on it ?
i aslo try to control right by SFU (win2003 srandard server,AD for SFU nis) ,install client ,nis sychroncs( we have unix and PC tester together ) ,but it only can work on server .the PC client can not share the server net resource .
I remember using a tool 5 years back on a Win2k system to limit the access. It is a policy editor called "poledit". You may want to look that up on the internet and see if it helps.
I used it to create additional operator logins - each one of them having the same policy. It was simple in this case because it just copy&paste the existing 3070 operator login and giving it a new name. If I remembered correctly, the tool have some useful options you can tweak. All the best.
Caution though : Always do a backup! ..just in case ...
