Hi Folks,
I am a newbie , I have connected a DSA and host PC using USB-GPIB cable . I have stored data to a file which is in DSA . Objective is to extract the file from DSA through Host PC . Is this possible ?. if yes how ?
Generally the :MMEM:DATA? command is used to transfer files to a PC that has been saved in an instrument. I would check the programming manual for this command.
