" yes, you do need to calibrate when making manual hot/cold measurements. You might find the attached .pdf guide helpful for this type of measurement "
Hi, So the pdf file you have sent to me is just for calibrate the noise-source and determine the ENR & kTB value of the noise-source. Now, what about measure the noise figure of the LNA? Any procedure?
