I have recorded some data as WFM files (I now, didnt know, that it would be such problem to visualize them) from Agilent DSO1014A Oscilloscope. Now I need to view that data as curves, which were on screen. Is there some possibility to open these data on PC or convert them into image file or in txt file? Or would be possible to Import those WFM files back to Agilent Oscilloscope and then save screen with that data as PNG file?
Thank for your help!
The easiest way that I know of would be to put the .wfm files on a USB drive and change them to .png files on the DSO1014A scope.
The process is as follows:
1) I always start by pressing "Default Setup"
1) Plug the USB stick containing the .wfm files into the scope and press the "Save/Recall" button
2) Press the softkey labeled "External"
3) Scroll to the .wfm file you want to convert and then click the "Recall" softkey (your waveform should now be displayed on the screen)
4) Press "Save/Recall" again
5) Press "Storage" softkey and scroll down to PNG
6) Press "External" softkey
7) Press "New File" softkey
8) Press "Save" softkey
Your USB drive should now contain the .png file that you saved to it from the scope.
