I'm having some difficulties getting HP ESA-L1500A to function with matlab. Every time I try to send a new command the instrument resets itself and then executes the command I've sent. I'm probably doing something (OK, probably many things ) wrong but can't really figure this one out...
Code:
inst = gpib('agilent',boardID,instrID);
set(inst,'EOSMode','read&write');
set(inst,'EOSCharCode','LF');
fopen(inst);
fprintf(inst,command);
fclose(inst)
delete(inst)
So I'm creating a new gpib object for all commands and closing it after executing the command. The above works fine with other instruments on the same bus...
Code:
fopen(inst);
fclose(inst)
delete(inst)
Please realize that the L1500A is not a scpi based instrument. Are you trying to send scpi to the analyzer? If so, you need to get a programming guide specifically for the L1500A, which has an older style command set.
Regards -
