While doing my measurements for OFDM 802.11n (pulse signal ) , a message of NOT PULSE FOUND appears , it seems that the search length is too short , the matter is that i can't adjust it, this is the configuration of MeasSetup > Demod Properties > Time tab
Search Length : 480 usec (i can't adjust it )
Result Length Selection :Auto Select
Max Result Length :60 symbols
Measurement Offset :0 symbols
Measurement Interval :60 symbols
thank you
thank you
What is the model number of the instrument you are using?
