Hi all,
I am trying to configure an 86142B OSA to save trace data and .gif files to a network share using Agilent VEE Pro 9.2. I am rather new with programming in VEE. The problems/questions I have been having are:
1) How do I automate the process of saving files to the network share? Do I use "MMEMory:FSHAre [1|2|3|4][:PATH] <param>"? For the [:PATH] do I just c/p the network file path (\\server\"share name")? What do I enter for <param>?
2) Also, I'm trying to automate the process of saving data and .gif image files, but when I use the "screen capture" and "display screen capture" user functions from the OSA library, I get an error message that the image cannot be displayed because of incapable file formats. These user functions are read-only though, so I can't edit them to change that problem.
3) What code do I use to enter info into the "User Profile for Remote Shares" (username, pw, workgroup)? Currently I have:
write text "SYST:COMM:NETW:USER", A EOL for data input through terminal A
write text "SYST:COMM:NETW:PASS", B EOL
write text "SYST:COMM:NETW:WORK", C EOL
This is taken from the programming guide for the 86142B OSA, but it doesn't seem to enter in any information on the OSA.
Any help/tips/suggestions would be greatly appreciated!
jtran
jtran
I also am trying to do a GPIB/remote screen save on an 86142B, it's unclear what the commands should be from reading the programming manuals.
Roy
