I need to do a nested parameter sweep of 7 independent variable/parameters on a Transient analysis.
In the help files, it was shown how to do a 2 parameter sweep on a DC analysis and successfully did that whilst being in Transient Analysis (sweep_config1.png).
Yet in those documentation, it wasn't explicitly shown how to go higher than 2. So I've been trying this setup (sweep_config1.png). It's still only 2 parameters, but meant to extend more, through Sweep Plan and Parameter Sweep pointing alternatively to each other.
In the Display, what I seem to be getting are 2 separate sweeps, but not nested.
It's also possible that I'm not using Sweep Plan properly, so I couldn't set the "Parameter to sweep", so I made it point to another Parameter Sweep.
Edited by: ren_zokuken01 on Mar 21, 2016 12:51 PM
