So far I seem to be doing ok with the basics of communicating with my DSO80204B and getting info to and from, but being no VB expert I'm having a bit of difficulty with my next task; saving the setup from the scope over GPIB, saving the file, then loading that setup back to the scope over GPIB.
I'm trying to use *LRN? to retrieve the setup, SYSTem:SETup to transfer it back.
My problems may simply lie in not being sure how to deal with the correct variable types and getting the context correct in VB .
Does anyone have some example code they can share? I'm first using hard coded file locations, I can add a dialog box for specifying file path/name after I get the basics working.
Cheers,
Jeff
Cheers,
Jeff
If you use the VISA-COM object in your code, it knows about ieee488 binblocks.
