Good morning:
I'm trying to create a new directory on the oscilloscope DSO90804A in the event that there is, as follows:
- Change directory
- If no exist, I create a new directory and change to the new directory.
But I get the following errors:
- When attempt to change the directory I get error -250 (Mass Storage Error)
- And when I try to create the -113 (Header undifined).
All this with the following code on VB6
.WriteString ":DISK:CDIRECTORY " & Chr(34) & saveas.Text & Chr(34) ' Change dir
.WriteString "SYSTEM:ERROR?" 'Error
result = .ReadString
estado.Text = "Direct:" & result
If result = -256 Then ' If error is -256 ci create a new dir
.WriteString ":DISK:MDIRECTORY " & Chr(34) & saveas.Text & Chr(34)
End If
The curiosity is that the same code to come to work in another scope, why not this?
Thanks
- Change directory
End If
Thanks
