Just installed the latest version of Intuilink Multimeter.
In the 'Connect to Multimeter' dialog, nothing appears under 'Select Addresses' - I'm assuming it should be showing the available COM ports. There are 5 available ports showing in Device manager.
(WinXP, Excel 2000)
Any clues..?
(WinXP, Excel 2000)
Any clues..?
will try to help. Is the Instrument identified in the Agilent IO libraries Connection Expert?
Most of our IVI-COM drivers require this step.
