When you are inside a VEE User Box with a lot of objects that extended off the visible screen, a scroll bar appeared on the right hand side. When there's a scroll bar, the program won't seem to let you connect directly to output pins by simply left mouse clicking on it (as it does without a scroll bar). I know there must be a way to do this. Any suggestions?
Thanks!
Thanks!
vrf-request@lists.it.agilent.com
