Hello
I have buy a lot off 2x HP8591A specrtumanalyzers_2xHP8591C Cable TV analyzers and 1 HP8591A. The CRT's from all that analyzers are pracitcal dead.Have 10 new CRT Omnivison LP0615E3Y and the replacement is no problem........but there are two analyzers with CRT Model TR- 60S1A from Matsushita (equal size and connectors) but the problem is that there is no Synchronisation . The screen give horizontale lines , ANY now what to do with these problem ??
Have 3 new CRT Omnivison LP0615E3Y in stock any need one PSE mail me
Thanks
Dirk
Belgium
Thanks
Dirk
Belgium
The 8591C has the same sync rate as the 8591E, which is 15.75 kHz, while the 8591As have a sync rate of 19.2 kHz. So you will need different monitors for each...
The OmniVision monitors you mention are the 15.75 kHz variety and were previously sold by Agilent as part of the 08590-60377 assembly for display replacement.
