Hi All,
I using 7104B scope and i need to collect many samples to perform analysis.
i set RIse time measurement, and start to wait Counter to reach 1K.
I realize that it took more than 1 second to reach samples count to 1k.
i measuring 50MHz signal, from calculation, i should get 1k samples at 200us.
what is going wrong and how can i speed up the time?
i tried to use :DIGitize command, but each time it only increase 2 samples count.
what is the command i can collect all data collected by oscilloscope? i need to collect standard deviation of all the samples data (let say 100k samples) , not the standard deviation of the average samples data (std deviation of 1000 data, and each data is averaged from 1000 samples).
I running measurement at Channel 1, and channel 2 is off. 4GSa/s.
this also happened on DSO5054.
any workaround or trick to collect all triggered data from oscilloscope? I can use PC to calculate standard deviation
Scope is able to collect alot data at a time, but the measurement mode only able "see" what display on scope.
if i change time scale to higher scale, i able to see a lot signal edge, but the measure count only 1.
I tried to use segment data but it required around 5 second to collect 250 segments.
how can i collect all data from scope and perform analysis?
i tried to collect all samples data, but max waveform data point i able to set is 1k. :WAV:POIN? return 1000 when i set higher value.
any idea and trick to do this?
Thanks
