Hi
When I want to read a voltage value of a waveform, at times I get a wrong value of " 99.00000000000E+36" (when communicating with an oscilloscope using GPIB). I do not know why I get this value. Has somebody experienced this and can explain this to me? Thank you.
But I had used the same command to read the values before too. This happens only at times. Also, When I change the source to a different channel in the oscilloscope, this wrong value appears( There are 4 channels in the scope). Is there anything that I should do before changing the channel ?
Thanks
