Hi there,
I just installed the Logic Analyzer Software 3.8 on our 903 Mainframe and the LA COM Automation 3.8 on the client side.
When I try to test the connection between client and Mainframe, the COM-Connection-Tool always crashs with the following error:
Visual Studio 2005 SP1 Runtime-Libraries for x86 are installed, also the .NET Libraries.
Can you please help me out?
Thanks in advance and best regards,
Michael Mzik
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x800736B1): Retrieving the COM class factory for component with CLSID {1681B88E-BF92-43F1-9457-75682184DA48} failed due to the following error: 800736b1.
at COMConnectionTool.frmGUI.btnConnect_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
COMConnectionTool
Assembly Version: 3.80.2.0
Win32 Version: 03.80.0002
CodeBase: file:///C:/Programme/Agilent%20Technologies/Logic%20Analyzer/LA%20COM%20Automation/COMConnectionTool.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Interop.AgtLA
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Programme/Agilent%20Technologies/Logic%20Analyzer/LA%20COM%20Automation/Interop.AgtLA.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Michael Mzik
No one else has this question
were not properly registered in the Microsoft OS at installation time.
I have only heard of this particular problem once thus far.
In that instance, we uninstalled the VSA software and uninstalled the agLogic main application GUI software.
Then we installed the VSA software version 9.00.0249 which we had been using.
(Note that there is a later version of the VSA software available...)
And then we installed the agLogic main application GUI again.
This uninstall followed by a istalling again allowed everything to work without error.
The system was Windows XP SP3 with .NET 3.5 SP1 and Agilent IO Libraries version 15.0 .
