I am using 54854A Infiniium Oscilloscope.
How can I open and edit ".wfm" file in vee?
".csv" or ".txt" files are too large to edit on my remote PC, so if possible, I would like to use ".wfm" file without conversion.
Best Regards
Best Regards
the scope's .bin file format. A sample C program describing the format
is available in the scope's help section under bin format. If your intent is
to edit the waveform file and insert it back into the scope, this is not supported.
