Adding a cyc-cyc jitter measurement displays 4 values on the scope: Current, Mean, Min, Max.
The following SCPI command appears to retrieve the Current jitter for channel 1:
:MEASURE:CTCJITTER? CHANNEL1
How can I retrieve the Min and Max values?
This gives you all of the results from all of the measurements on the bottom of the screen...
AG
Many thanks,
Martin
