I am trying to setup gpib over lan.
Problem is, port 5025 is not open.
Normally I should be able to
% nc infinium1 5025
and get at least a connection.
But as I said port 5025 is not open
(nc says "connection refused")
Is there something I have to do to open this ports?
The lanserver on the oszi is started on boot.
With best regards
p90
[EDIT]
Oh my.
Corrected some tipos.
I found a error in the Log.
It says that iopen() failed. If you can trust the documentation this is caused by a faulty configuration in ioconfig
Has anyone the default configuration for the Agilent 54845a?
% nc infinium1 5025
With best regards
p90
[EDIT]
Oh my.
