Moving ports in modified layout...
Question asked by Uky on Feb 3, 2010
Latest reply on Feb 4, 2010 by Uky
Having modified a design and then updating the layout only to find the original ports
hanging in the air.
sigh...
The ports can be seen: Chosing port_editor in the menu of Momentum, and then snapping to the
port coordinate in the layout window. Carefully zooming with the scroll-wheel on the mouse
makes the port visible - but only for one specific zoom level.
Once found, I have not found any way to move the port to where my modified layout
has its entry and exit pins. I have to delete the port by pressing <del> key when it is
visible, the go back to the design and delete and reinstate the terminations (In this
case S-parameter ports). Then recreate the layout and voila! The ports are where
they are supposed to be.
Naturally I assume that there is a better and more obvious way to do this
or a flag that should be set during layout regeneration but I have not discovered it.
Can somebody point me in the right direction?
