Hello
I'm trying to obtain the voltage transfer function of a circuit from the S-parameters.
I thought it could be the function volt_gain, but employing a simple circuit (like a voltage divider, for example ) from which the transfer function can be easily obtained in oder to compare them in the simulation, I see that the results are not the same.
What is the difference between them?
Thank you very much
Thank you very much
