I have been trying to optimize an inductor in a modern deep-submicron CMOS technology. Since the via resistance is pretty important, I add a stacked via structure from low-level metal (metal-1) to top metal (metal-8). However, when I add the sea of via (let us say 10x10 vias at per metal layer), the simulation takes so much time (days).
I know vias cause increased simulation time. However, the vias I used are regular structures. They repeat again and again in the same layer. Is there a trick to reduce the simulation time for this kind of regular/symmteric structures in Momentum environment?
Thanks in advance.
Thanks in advance.
