Is it possible to sweep the values of an array rather than sweep a Start Stop Step (or a multiple of Start Stop Step). Here is a very simplified example of what I am trying to do.
Take just a simple FET with its Gate connected to voltage source VG Drain to voltage source VD and Source is grounded. VD is fixed at 3V and VG is to be varied by these amounts [0.1, 0.115, 0.2, 0.95, 0.335, 0.4, 0.5, 0.545, 0.58, 0.6, 0.725, 0.785, 0.81, 0.865]. How can I do that?
(Please don’t wonder why I need to sweep these values, this is just a non-real simplified example to resemble what I am trying to do in an easy-to-understand way but what I am actually doing is something totally different from this)
This array of values does not have any particular Start Stop Step form that I can use in the DC Simulation component, ParamSweep or the SweepPlan components. So is there any way to run this sweep?
Thanks in Advance
Thanks in Advance
An alternative is to run Batch Simulation: see $HPEESOF_DIR/examples/Tutorial/BatchSim_Example1_prj.
