after a period of non-use my hp8753E network analyser has started to display everything upside down. All of the display is inversed.
Has anybody ever come across this before?
Thanks in advance
Thanks in advance
FYI, here was our most recent experience in using an Agilent/HP 8753 with ADS:
"ADS2006A Connection Manager(CM)/Agilent IO Libraries Suite 14.x Connection Expert: Can you walk me through the steps to use ADS 2006A Connection Manager(CM) to capture measured data from my Agilent 8753ES Network Analyzer over GPIB (Optional: use Agilent E5810A LAN/GPIB Gateway)?":
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&_schema=PORTAL&itemid=296856&search=8753&ref=search
Best Regards,
Mark
