Hi! Why when I simulation a board in EMDS for ADS,the "EMDS/Job Control"will display "ERROR",while I delete some geometrys it can be mesh done and later(PASS2-3) notice ERROR,I delet geometrys more the "ERROR"will be apper later(PASS9-12).
The tetrahedra usually in PASS1 are 40XXX tetrahedras
,In PASS2 will be more than 42XXX.
Is my Computer too weak?
the
sub define
Free Space
----STRIP-cond resi
air |VIA| sub1
///////////////GND///////////////
Thanks!
-CQCQ
the
sub define
Free Space
----STRIP-cond resi
air |VIA| sub1
Thanks!
-CQCQ
EMDS 332.400 Copyright (C) 1996-2008 by Agilent Technologies
Computer Operating System: Microsoft Windows XP Service Pack 3
Pass 1 : Mon Oct 20 20:32 2008
PORTS 1
CPU time: 00:00:00
GRADE 1
CPU time: 00:00:01
MESH 1
Geometric Project Ratio 2.758870e-001
Using mesh scaling value of 1
Using mesh grading value of 0.9
Loading ACIS File F:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.sat
Generating Mesh
Creating Solver Files
7460 Points
40467 Tetrahedra
PORTS 1
SOLVE 1
Solver: LSSpack 32-bit
Frequency: 1.000000 GHz Unknowns: 245384
ERROR
Total CPU Time = 00:00:01
Total Elapsed Time = 00:00:50
Delet near a half geometrys
Pass 1 : Mon Oct 20 20:41 2008
PORTS 1
CPU time: 00:00:00
GRADE 1
CPU time: 00:00:01
MESH 1
Geometric Project Ratio 2.500000e-001
Generating Mesh
5198 Points
28147 Tetrahedra
PORTS 1
SOLVE 1
Frequency: 1.000000 GHz Unknowns: 170780
CPU time: 00:00:54 Memory: 910.86 Mbyte
Pass 2 : Mon Oct 20 20:42 2008
ADAPT 2
Read 1407 points
Loading Mesh File F:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.vol
5696 Points
30702 Tetrahedra
PORTS 2
SOLVE 2
Frequency: 1.000000 GHz Unknowns: 186952
CPU time: 00:00:58 Memory: 985.68 Mbyte
Delta S: 0.002003 [Target: 0.010000]
DONE
Total CPU Time = 00:01:53
Total Elapsed Time = 00:01:45
