If I try to plot one of the Goals in DDS, it only re-plots the current response rather than the goal. Is this a bug or am I using the parameter incorrectly?
I am not sure I am understanding your question correctly. It may help if you contact your local Technical Support office and describe the request to them. I am sure they will be able to clear this up very quickly.
http://edocs.soco.agilent.com/display/a ... timization
1. Make sure that "Goals expressions" is checked in the Optimization Controller.
2. Then plot the goals in DDS.
I hope this helps
Nilesh
