Hi all, first time using co-sim, tried the examples, they worked.
When I inserted my circuit which has two inputs and two outputs (I, Q)the simulator coughs up;
"Could not find transient or env analysis for cosimulation of circuit X12.R17 or one of its neighbors"
R17 is a resistor in the subcircuit, which happens to be on one of the two outputs.
If I deactivate the sources and sinks on any one path it will then simulate.
Is co-sim limited to 1 path per subcircuit where a transient controller resides?
thanks
charlie
cmoses5
thanks
charlie
cmoses5
thanks
charlie
cmoses5
