Advanced Model Composer AMC - accuracy configurable?
Question asked by MARTINK on Aug 10, 2009
I need control about the accuracy of the AMC process. The Knowledge Base says
"... If you still want to increase the AMC modeling accuracy, you can modify it with a config variable ... MAPS_SET_ITER ... in the config-file: $HOME/hpeesof/config/pmlg.cfg"
but there is no file 'pmlg.cfg' in my $HOME/hpeesof/config directory (ADS2009).
So how the AMC accuracy can be controlled in ADS2009?
In advance thank you for any hints.
Martin
