1- Does EMDS support multithreaded operation? If it does, how can I set it?
2- What are the reasonable numbers for Delta Error and Limit on Number of Adaptive passes? This issue is very important, the simulations take so much time.
Burak
Burak
If simulations take a really long time, you can also try setting mesh to Minimum, and of course, trying to simplify the geometry as much as possible.
