Hi
I have ADS2006A installed on a WinXP 64 bit machine. I run ADS2006A in 32bit mode.
I have setup a matlab by running matlab /regsvr in the command prompt to setup DDE/COM as mentioned in the documents.
If I run the matlab example (setup the correct path for th m file) I get an error saying 'abnormal simulator termination' and then a window message box saying 'hpeesofsim.exe has encounterd a problem and needs to close...' etc.
Please can someone advise me on how I can setup matlab to work with ADS. The matlab version I have is 7.3.0.267 (R2006b)
Thanks in advance
Marino
Thanks in advance
Marino
MATLAB Release 13 (version 6.5 Service Pack 1)
MATLAB Release 14 (version 7.1 Service Pack 3)
This is mentioned in the "ADS Ptolemy Simulation" manual, "Introduction to MATLAB Cosimulation" chapter, "Supported MATLAB Versions" section.
Other versions of MATLAB have not been tested with ADS 2006A; they may or may not work.
