I have measured channel responses and i want to use the delays of that measured responses as delayfinger values in UWB rake receiver correlator>> rake finger correlator ( present in UWb design guide). when i ll specify the values using Data access component (using discrete file) and try to sweep DF using Parameter sweep. it will give error Parameter N of instance rake finger.Dx is not modifiable.
can anyone sort out my problem please. i m stuck here and i spend almost one month to solve it but all in ruin.
How many points are you trying to sweep over? If not many, then you can just run the individual simulations.
