we have two computers, both were installed ADS 2008 update1.
i simulated the same structure on both computers, but got different results!
i am total confusing.
who can explain this problem? and which result should be trusted ?
more details about hardwares:
both computer are using Windows XP 64bit system.
both computer have Intel duo core 6600@2.4G CPU and 4 GB RAM.
the only difference between two computers is that one uses Gigabyte 965p-D54 mainboard, the other uses Gigabyte p35-D54 mainboard.
Based on what you are simulating, different results could be normal, corner case, or a bug. Also if this issue is urgent, you may have a faster response by submitting it to your local technical Support office.
-Nilesh
