Hi everybody!
I'm trying to simulate a structure consisting of a dielectric resonator placed above a microstrip line. The resonator is machined in such way that it is in direct contact with the substrate and the strip (see resonator intended), so the strip is inserted into the resonator
I have created the following substrate:
FreeSpace
--- cond ---diel
Alumina
GND
Cond is mapped as a thick conductor (up expanded) and diel as a thick dielectric (up expanded)
When creating the 3D model for the FEM simulator, it performs an intersection of both layers (see resonator obtained). How can I troubleshout that?
Thank you!
FreeSpace
--- cond ---diel
Alumina
GND
Thank you!
