Hi!
Im doing a batch simulation using the batch simulation controller for a specific circuit and i would like to change variables and do a sweep at the same time.
For example CVS_List format permits to define variables and alter them for each simulation and
CVS_sweep Format permits to define different sweeps for each simulation.
But they are independent. What i mean is or you define variables and their values or you define a sweep for each simulation. You can not do both.
What i would like to do is:
Define variables
Define sweep
simulation run 1
Define variables
Define sweep
simulation run 2
It sounds like mixing the two types of Formats mentioned before.
is that possible? Or exist another Format type that permits to do that?
Best regards
Canosa
Define variables
Define sweep
simulation run 1
Define variables
Define sweep
simulation run 2
Best regards
Canosa
you can play with a DAC,(Data Access Component) and sweep the index of the DAC . in the dependant variables of your DAC you may be able to change a variable and a sweep. look at examples with DAC.
br
