Hi
I am trying to create a simple model library as described in the ADS help documents.
I have set the environment variables as required however when I run hpeesofmb after navigating to C:\users\default I get a set of errors
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\WINDOWS>cd..
C:\>cd users
C:\users>cd default
C:\users\default>hpeesofmb
: command not foundU1/adsptolemy/bin/hpeesofmb: line 3:
: invalid option009U1/adsptolemy/bin/hpeesofmb: line 4: set: -
set: usage: set [--abefhkmnptuvxBCHP] [-o option] [arg ...]
: command not foundU1/adsptolemy/bin/hpeesofmb: line 6:
/cygdrive/c/ADS2009U1/adsptolemy/bin/hpeesofmb: line 7: syntax error near unexpected token `{
'cygdrive/c/ADS2009U1/adsptolemy/bin/hpeesofmb: line 7: `usage () {
Can anyone shed any light on what these errors might be?
Thanks
C:\WINDOWS>cd..
C:\>cd users
C:\users>cd default
Thanks
To access this shell press the Start button (at the bottom left corner of your desktop) then select All Programs > Advanced Design System 2009 Update 1 > ADS Tools > Ptolemy Modelbuilder Shell. The path I described here is valid for Windows XP. It may be slightly different on Vista or Windows 7.
This shell makes sure all variables are set up properly.
