How would you setup your circuit to obtain the primitive operating-point parameters on a device in a Spectre simulation? Then, how can you get that info back into IC-CAP for extraction purposes?
More info. I am trying to gain access to the output parameters of a operating-point analysis for a device. In spice3 format it would be a .OP in the netlist. How do you setup ICCAP to run this part of a DC analysis and then have access to the results for extractions within ICCAP?
