Hi everyone,
I have some troubles trying to launch components through a AEL script.
In fact I did it without problem with older ADS version (2006) but it seems not to work anymore (2009).
Here is the code line I use (I do not give above code which includes schematic opening and so on...):
decl init_comp = de_init_item("TimeDelay");
The error message is:
(..\..\..\projects\pde\ael\de600toDE.ael) TimeDelay
Failed to locate the component definition
It works fine with the following components:
decl init_comp = de_init_item("Port");
decl init_comp = de_init_item("GROUND");
but it doesn't also work with:
decl init_comp = de_init_item("MeasEqn");
Does anyone has a clue ? Best regards,
Pascal
Pascal
