I am designing a LNA. Therefore I have designed a PCB-layout and created a component to place it in schematics.
When I annotate the DC-solution, something strange is happening. In a node, the incoming currents are different from the outgoing currents( eg in every node I lose about 30 micro ampere). This isn't a big current but it is 30 percent from the incoming current.
Does someone know the reason for 'losing' a bit current?
