Can you define mix()?
I have posted this question to support, but I am hoping I can get a faster response here.
I have a number of functions written in Matlab that I am using for post-processing my simulation results. In order to make my code as compatible as possible with ADS, I am trying to use the same syntax as AEL expressions when I can.
I am trying to write a function that will calculate the intercept point like your ipn( ) function. In order to do this I need to first create a function that does what mix() does, but it says that it is a built-in function. Can anyone tell me the definition for this function? I have read the description in the measurement expressions manual, but it is unclear to me how this function is written.
If you don't know the actual AEL code, can you help me better understand what it does, so that I can write the function myself?
Ali
